Automatic Shut-Off
  • Automatic Shut-Off
    I'm in the market for a heavy-duty wet-dry shop vac.
    Perusing the specifications for various RIDGID models I haven't found any verification of which models, if any (or all ) have an automatic shut-off triggered by the drum being full.
    Re: Automatic Shut-Off
    Seems to me that a loss of suckage would be a good indicator that the drum is full.
      Sure. That would indicate it.
      My question is more directed at whether waiting for that particular indicator would damage the unit.
      Other vacuums incorporate a float ball that activates an electrical shut-off of the motor.
      Still others use a float ball to block the vacuum inlet, protecting the motor/pump from liquid entry.
      The motor then gets much louder, alerting the operator to empty the drum.
        Found the answer in the .pdf of the owner's manual on pages 2 and 11.
        They use a float blocking the inlet manually to protect the motor/pump.
