ON/OFF Switch TS 3660 Table Saw
  • ON/OFF Switch TS 3660 Table Saw
    I bought a TS3660 and it won't turn on. I thought the switch was bad. Order new one but still won't turn on. The switch has no resistance between on and off. Any suggestions?
    Re: ON/OFF Switch TS 3660 Table Saw
    Did you buy it new or used?
      I bougth the saw used.
        I have to ask... do you have the yellow safty in the switch?
          Also, check the connections in the motor for the power cord to make sure one or more haven't come loose.
            I'm glad you ask. I know nothing about a yellow safety. What is it, where does it go and where do I get one?
            I found the yellow safety key on the floor....didn't know what it was...what a dumb butt. Thanks for your help, problem solved.
              Glad you are up and running now. Safety keys for switches are good to save children from getting hurt but they are also a P I T A at times.
                Welcome to the forum. You will find alot of good people with good advice. Pat
