ts3650 question
  • ts3650 question
    I am in the process of putting my shop back together after moving to the wilds of Kentucky. I removed the blade from my TS3650 to clean it and have a question. should there be a washer against the arbor flange? ie arbor flange, washer, blade, arbor nut? its been about a year since i have powered up the saw and really can't remember. also, I have a Delta dado set currently. can anyone recommend a better one that will fit the 1 1/8" arbor? thanks for the help
    rj
    Re: ts3650 question
    No, the washer should go on the other side of the blade (ie - arbor, blade, washer, nut). That's the way it's shown in the repair guide (check out the diagram on page 18 of 19):
    http://www.ridgid.com/ASSETS/FD9D936...3650_402_r.pdf
    Not too sure about a dado set. Freud makes some good stuff though, and nice blades and dados, but I'm not sure if they specifically have a dado set to fit that arbor - they should though, it's a pretty common size.
      Re: ts3650 question
      If all you cut are dado's that are under an 1ΒΌ" deep then the Freud SD206 would be a good choice for a dado set. If you cut dado's that are deeper then you'll need to go with an 8" dado set. As far as I know, the only dado set that won't work with the 3650 would be the Freud SD600 Series sets.
