24 volt XLI
  • 24 volt XLI
    Can the 24 Volt XLI cordless tools use the 18volt lithium ion batteries?
    Thanks
    Re: 24 volt XLI
    I believe every tool sold as part of a 24V kit that will work with 18V batts is detented for them. If memory serves my 24V XLI hammer drill will accept a 18V batt and my circ saw will not.
      Re: 24 volt XLI
      Thanks for the reply.
      The drills are where my concern lay, As I use them must of the time.
      Thanks
        Re: 24 volt XLI
        AM.............If you use a drill alot, I strongly suggest you consider the Ridgid 18V LI Compact drill. It has become my favorite all around drill because it has sufficient power for most jobs even using the 1.5Ah batts. It is light with beautiful balance, great trigger control and our experiance over the last year and a half has been faultless performance in filthy demanding professional usage working conditions.
