Twin Stack compressor 45150
  • Twin Stack compressor 45150
    The motor blew up on my compressor and the only part i can not find is the crankshaft. When the rod went it took out the crank bearing too. Or does this come with the piston kit?
    I can't seem to get any parts person that knows the answer...
    Re: Twin Stack compressor 45150
    Ttt
      Sorry no one has responded. I saw your post, however I have no real knowledge of that compressor.
      Have you tried Ridgid customer service at 1-888-743-4333 or Ridgid Parts at 866-539-1710?
      Good luck....Ray
        the bearing or crank is not available separately, rod/cylinder kit does not include the bearing, if crank is ok you may be able to match bearing at a supply house
        if still under warranty they will replace complete motor/pump assembly
