Do all the ridgid battey chargers have cooling fans?
  • Do all the ridgid battey chargers have cooling fans?
    I bought a 18v charger and a 18v/24v cir. saw on ebay and the charger s cooling fan dose not work, the seller said that modle saws charger dose not have a cooling fan. Is this right?
    Re: Do all the ridgid battey chargers have cooling fans?
    There has been alot of people view this. Dose anyone have a answer? How about a guess?
      Firemedic309,
      Welcome to the forum. There are basically 4 types of chargers that you will run across. 3 will charge all battery voltages from 9.6 volts to 18 volts and 1 is dedicated to the 24 volt power source only and it has no cooling fan. Of the 3 chargers that will charge across multiple battery voltages, one (1) of the chargers, the most current release, will charge not only the NiCad batteries, but also the newer lithium releases and it also has NO fan and bears the LITHIUM ION logo on the front left panel of the charger. The 2 remaining earlier model chargers were designed to charge NiCad only batteries and only one of those two, the DUAL PORT model, has the fan cooling system. Hope this helps.
        thanks for the help!!!!!!!!!!
