WD1250 vs. WD1450 -- IS ONE BASICALLY AS GOOD AS THE OTHER?
  • WD1250 vs. WD1450 -- IS ONE BASICALLY AS GOOD AS THE OTHER?
    According to the published specs, by buying the WD1250 instead of the WD1450, I'd be giving up 2 gal. tank capacity, 5 ft. of cord length, and 1 hp (peak cap.). Everything else seems to be about the same, except the 1250 is significantly lighter AND I'd save about $20.
    I don't need a lot of tank capacity (minimal usage) or cord length (tiny workshop) . . . and the weight difference would be a lot easier on my already-strained back.
    Is there any big advantage to the 1450 that I'm overlooking?
    Re: WD1250 vs. WD1450 -- IS ONE BASICALLY AS GOOD AS THE OTHER?
    I have a 1450 and for $20 I would want it over the 1250. Excellent vac, quite compared to most. The lighter weight is the smaller motor I bet. The footprint is about the same, mostly vertical.
