dado on the ts3660 table saw
  • dado on the ts3660 table saw
    Guys,
    Will most dado blades fit on the ts3660 saw? I have read that some saws do not have a long enough arbor to use dado's. I need to be able to fit at least a 3/4" dado on it.
    Thanks
    Re: dado on the ts3660 table saw
    No problem. It will accept up to 13/16.
    John
      Thanks john
        It should fit but you may need to mount the arbor nut without the washer...a common and recommended practice by many manufacturers, Freud included.
          To the best of my knowledge the only dado sets that won't to their full capacity on the Ridgid TS3660 are the Freud SD606 and SD608. All others should work just fine.
            How well does the Freud SD206 work on the TS3650? All I want to be able to dado is cabinet grade plywood
              I have a 3612, earlier version of the 3650/0660, and my SD206 works just fine on it.
                It works fine for me.
