PowerWasher 3000 2.6gpm Extension
  • PowerWasher 3000 2.6gpm Extension
    Recently purchased Ridgid PowerWasher 3000 with 36" extension wand that I can't seem to connect properly - now noticed the wand is a PowerCare which is not Ridgid - could that be my problem - the HD employee told me it worked with the Ridgid. Any ideas?
    Re: PowerWasher 3000 2.6gpm Extension
    it should work. The description on hd website say the wand comes with a quick connect fitting. this is probably for the spray nozzle. it also says it comes with a bonus quick connect fitting. Looks like you have two options.
    one is use the existing wand that came with the pw and insert the new 36' extension wand into the quick connect fitting on the old wand. the other option is to just use the 36 inch extension wand. screw on the bonus quick connect fitting to the gun, then attach the 36" wand to the gun. The other end already has the quick connect fitting so you would just insert the spray nozzle.
