AC9944 msuv
  • AC9944 msuv
    I just bought this table and have my saw mounted to it and really like it for storage space and ease of set up and mobility. Have been looking on line for another set of mounting brackets and can not find any where to order them. I want to get another set of mounting brackets so i can quick change from the saw to my planner. Where do i find the mounting brackets. The ridgid site does not reconnize the part number nor does it list the msuv on the site and Home Depot does not stock them. Any help out there.
    Re: AC9944 msuv
    Call the Ridgid Power Tool Division at 1-866-539-1710, they will be able to help you out with gettting the parts you want.
      Re: AC9944 msuv
      http://www.ridgid.com/Tools/AC9944-M...ility-Vehicle/
      http://www.ridgid.com/ASSETS/945CDF6...43_r_sheet.pdf
      here are a couple of links that should help you out.
      the second one is the PDF page for you're part numbers.
      you should be able to go to ridgidparts.com to order what you need. in the past though i have seen people say that if you catch the stand on sale for $99 its not much more than just the mounting brackets alone.
      hope this helps.
        Re: AC9944 msuv
        Was more wandering if could find at a distributor to save on shipping, if can't find will end up calling them.
          Re: AC9944 msuv
          hope this helps.
          Have been to these links but not able to order this way with out calling, I still have the parts sheets that came with it so will try to find a local distributer before calling to try to save on shipping cost. Thanks for the links.
            Re: AC9944 msuv
            It seems the only place you can get extra mounts is order them thur Home Depot. They stock ordered them for me no freight charge. 10 to 14 days. at $45 and change for the pair including tax not bad to be able to quick change tools on the stand.
