R3030 Fugeo Reciprocating Saw - Jigsaw Blade Replacement
  • R3030 Fugeo Reciprocating Saw - Jigsaw Blade Replacement
    Does anyone know where to find a replacement jigsaw blade for the R3030 Saw? I have asked at Home Depot and no one seems to know anything about them. And I cannot find anything on Ridgid's website. Thanks
    Re: R3030 Fugeo Reciprocating Saw - Jigsaw Blade Replacement
    It uses standard reciprocating saw blades.
      Page 10 of the manual talks about blade selection, use, etc. However it does not mention anything about replacement blades in the manual that I saw.
      Not owning one myself and just looking at the illustration in the manual I would have to say its a standard recip saw blade, why would they design it to use anything other than that? If it tool a proprietary blade, no one would buy it because you could not share blades with a full size recip saw.
Name:	recip blade.JPG
      Go to the tool section in HD, Lowes, Sears, or any hardware store and buy regular recip saw blades.
        I understand that it takes standard blades and how to change them, but the saw comes with a unique blade that is the size of a jigsaw blade but is designed to be received by reciprocating saws, the end looks like typical reciprocating blade. It is a very small blade in comparison to the smallest blade I could find in the blades section. The blade was stamped with Ridgid on the side so I know they are the manufacturers. I hope that clears it up a little better. Thanks for any insight into this.
          These?
          Mikwaukee scroll hackzall blade
          Ern
            Thank you, those are the ones. I was beginning to worry I was not going to be able to find a replacement, it is a very handy little blade.
              I've also seen similar ones for pneumatic saws in the air tool section. I think they use the same mounting system as reciprocating saws.
                Originally posted by erngum View Post
                I keep forgetting that TTI is the GM of power tools now. Everything they make comes in the equivialant of a Chevy, Buick, Pontiac, Olds or Caddy version (Ryobi,RIDGID,Milwaukee,AEG).
                Strange how Ryobi and RIDGID came out with an Auto-Shift drill at the same time isn't it? And RIDGID and Milwaukee have a one-hand sawzall.
                  That is a very handy little blade. I had some made by Dewalt, but when I went to buy more I couldn't find them anywhere. I'll be on the lookout for the Milwaukee blades.
                  You only live once, so play with your tool often.
                    I had the same problem at 5 different H.D stores. No one stocks them. Go to www.gardnerinc.com. They are a parts company for rigid/ryobi/homelite and about 50 other tool companies. Their phone # is 1-877-544-9253. They are in Columbus, Ohio and Jacksonville, Florida. I really like mine for small jobs.
