Bad Vibes
  • Bad Vibes
    I need a little help. I have a BS 14000 with a severe vibration problem. I’ve been trying to work out the vibration but don’t seem to be getting anywhere. Thus far I’ve balanced the wheels and replaced the OEM tires with urethane ones but it hasn’t improved thus far. I recall reading something about the use of link belts to help reduce vibration. I also seem to vaguely recall that the pulleys will need to be replaced. If I’m remembering right, I think I read that the link belt would chew up the aluminum driven pulley. Am I remembering correctly, or have I been spending too much time in the garage sniffing varnish fumes? If I need to replace the pulleys, can someone recommend a supplier? TIA
