TS3660 Motor position
  • TS3660 Motor position
    When I installed the motor per the instructions the belt was very loose. So I pulled the motor out a little so there was no slack on the belt. Is this how the motor should be positioned? Or is there another mthod?
    Thanks
    Re: TS3660 Motor position
    The weight of the motor is what tensions the belt. My guess is you didn't do something correctly when you installed the motor the first time.
      I just slid the motor's mounting rods in as far as it would go, like the directions said.
