Replacement for MSUV clamp handle
  • Replacement for MSUV clamp handle
    Has anyone found a better replacement for the clamp handle (000900510049) on the MSUV. I have had mine for about a year and really like the setup, but I have had two of these handles break on me. They apprear to be made out that cheap potmetal. Just wondering is anyone has found a better set up? Has anyone else had this problem? I had ordered the replacements from ereplacementparts, but now they are on B/O for a month, and its a pain to have them break.
    Thanks,
    Re: Replacement for MSUV clamp handle
    is this on the new model or the original model MSUV?
      Ac9940 The part number in the manual is
      829742 Handle
      They are only 5 bucks a pop, but just a pain when you are in the middle of a job and they snap off
        829742 Handle
        No longer available and they've been discontinued (thanks Rigid). Going to order a set of valve cover T-bolts (Mr. Gasket 9823) 5/16-18 to see if they'll work. Same thread size as old retainer. Less than $20 and should last longer than the stock parts.
          Re: Replacement for MSUV clamp handle 829742
          This pot metal lever knob (829742) is a poorly designed piece of junk to begin with and now is no longer available with no replacements (thanks a lot Rigid). The quick fix is to use a 1/2" box wrench in place of the lever knob - you get the same functionality. Just remove the phillips screw holding the lever knob. Replace the lever knob with the 1/2" box wrench and replace the phillips screw. I use a cheap combo wrench from Harbor Freight and cut off the open end part of the wrench. Works great.
            Thank you for a great solution. I spent way too much time looking for the replacement part - only to find that RIDGID forgot they ever offered it from the fourth-world island that made that piece of junk. I'll stop by Harbor Freight on the way home. Thanks again!
