problems with 3000 psi 2.6 gpm washers water shooting out of soap nibble on pump
  • problems with 3000 psi 2.6 gpm washers water shooting out of soap nibble on pump
    hign pressure water shooting out of soap nibble on pump near where the high pressure hose connects.
    Does anybody know what brand of pump it has and can you find parts for it?
    Re: problems with 3000 psi 2.6 gpm washers water shooting out of soap nibble on pump
    post what brand and model number of pressure washer you have, that nipple is the chemical injector, take the nipple out and clean inside,clean the small steel ball, careful when removing nipple, there is a small spring and small steel ball inside, if you use bleach they will corrode and leak,
    if its still under warranty you can take it in for repair if its not corroded due to wrong chemicals
    if its a ridgid, parts are available at you local ridgid service center
