R4121 or MS1250LZ
  • R4121 or MS1250LZ
    What are the advantages of choosing one or the other of these two miter saws. I see the first is $50 cheaper and appears to have greater capacity of cut, but the MS1250 looks to be four pounds heavier(stouter?), direct drive and wider range of bevel cut. I'd value other's opinions of these two saws. Thanks
    Re: R4121 or MS1250LZ
    So, neither one is worthy of purchase? Guess I should look at other brands.
      I don't own either of these, but I do have the slider and am happy with it. The 4121 is a newer saw with smaller footprint than the 1250lz, I think thats where the weight difference may be hiding. 4121 is also a dual compound miter saw which is a nice feature. The clamp design is different too. 4121 holds stock down on the table while the 1250lz holds it against the fence, matter of preference though. The 4121 has a more cutting capacity than the 1250lz.
        Satchel,
        What did you decide?? Did you take a look at the 1250LZA slider at all?? It really is a great MS.
