TS 3660 power supply
  • TS 3660 power supply
    I'm considering buying a new 3660 table saw. The motor is rated at 13A on a 120v circuit. Has anyone had any problems running this saw on a dedicated 15A circuit, or would it be advisable to upgrade to a 20A power supply?
    Re: TS 3660 power supply
    If all that will be on the 15A circuit is the saw then you should be alright. On the other hand, if there will be other stuff sharing the circuit then adding a new 20A circuit wouldn't be a bad idea.
