10in Cast Iron Table Saw...HELP!!!
  • 10in Cast Iron Table Saw...HELP!!!
    Recently bought the Ridgid Cast Iron Table Saw and I seem to be having a little difficultly with the belt. I have a feeling that the belt is too big (which seems ridiculous as I took it out of the box this morning). Has anyone else experienced similar issues? I have played around with it and troubleshooted every way I can think imaginable but the belt still slips off every time I go to start it up.
    Thanks
    S.
    Re: 10in Cast Iron Table Saw...HELP!!!
    Is it tensioned correctly?
    Try this procedure: http://www.ridgidforum.com/forum/sho...36&postcount=9
      Thanks chris
      I took all the info I got from you and the guys at Home Depot and decided that the problem was me...so I just went through all the steps again and it seems to be working ok now...there also seems to be some left to right movement in the way the motor itself it mounted so I played with that a little bit and so far everything seems to be working better.
      thanks for the reply
      S.
