dado blades
  • dado blades
    I just bought a Freud Dail-a-matic dado kit but the arbor bolt on my 3660 isn't long enough to put all the pieces on and still put the nut on. any suggfestions???
    Re: dado blades
    Return that dado set and buy either the SD500 Series, SD300 Series or SD200 Series set. The SD600 Series set will not fit many table saws due to the arbor length issue so that problem is not unique to Ridgid.
      Re: dado blades
      +1. It's either that, or only use the dado to a width that will fit your arbor. FWIW, the SD508 has the same tooth configuration as the SD608 DAW set.
