WD1460 Shop VAC
  • WD1460 Shop VAC
    Can you pick water with the 1460 with the paper filter or do I need to put something else on it. Half about 1/2 water on the carpeted floor of the basement and need to get it up.
    Please check out my web page
    www.woodandwax.net
    Re: WD1460 Shop VAC
    Answer - Yes
    You want the cartridge filter to be on the motor head anytime you are sucking up anything. This keeps dirt and other junk from going up into the fan and making a real mess of things.
    Be sure to empty drum and brush off filter. Then you're ready to suck up mud or clean water. When done empty drum and allow to dry. Next, remove the filter and clean it. To do this you soak it in dishwashing detergent mixed with warm water and then rinse under running water but so it flows from the inside outward. Be sure to allow filter to dry before reinstalling. It's a good idea to have a spare filter for when you need one.
    Note: Allow motor head to dry before putting it on the drum.
    SAFETY: Be sure to always unplug the power cord before opening the vac or doing any service. This can't be stressed enough. Always PULL THE PLUG FIRST
      Re: WD1460 Shop VAC
      Graet info Woussko thanks alot.
      www.woodandwax.net
