Dumb Vac question
  • Dumb Vac question
    I wanted to ask yall about the Ridgid vacs I have a 4.25/12gal wetdry vac and I either have the wrong filter or am I missing a part, The filter is in the vac,the nut that holds up the filter is there. but i think that this nut holds up a circular ring that holds the filter in place or do I just have the wrong filter for it. Thanks in advance, Joel
    Re: Dumb Vac question
    there should be a round plate that fits up against the filter itself anthen the nut goes on.
      Yup ....... the bottom filter plate comes off.
      A filter plate does not come with the new filter.
        Sometimes in removing and cleaning the filter, the filter plate falls off into the dust bin, leaving you with the open-ended filter. If you're not careful, you'll end up loosing the plate.
        I noticed that my local Home Depot carries both filter plates and nuts in their Ridgid Vac accessories.
          you could probably make one.
          Vince
            If your HOME DEPOT doesn't have it, check at SEARS as many CRAFTSMAN vacs use the same filter(s) as do RIDGID. As others have stated you want a replacement end plate and you may as well get the plastic nut too so you have a spare handy.
