Saw blade size ?
  • Saw blade size ?
    Greetings.
    I am a novice woodworker and bought a Ridgid portable table saw. The question is, is there any problem with using a smaller blade than 10"? I need to make just a few fine cuts and would like to use a good 7 1/4 blade from my circular saw rather than purchase a 10" just for a few cuts. It's only for ripping some 1x. Thanks for any advice.
    Neil
    Re: Saw blade size ?
    As long as the blade will raise up high enough to cut all the way through the lumber, there is no reason why you couldn't do that.
      There is always the issue of Arbor size as well....
        If both blades have the same hole size you should be OK. Normally a 7-1/4" blade won't have a 1 inch center hole like most 10 inch blades do. In addition as BadgerDave stated it may not rise high enough through the table insert slot.
          actually most 10" blades have a 5/8" arbor, as do 7-1/4"
