R6903cfa oil free pneumatic hub-2 nailer combo
  • R6903cfa oil free pneumatic hub-2 nailer combo
    Hi, I just purchased this item last week and have used it twice. After the air compressor tank reaches its pressure and you use one of the nailers, the tank loses pressure and does not automatically repressurize. I have to drain the tank, press the reset button in order to reuse the air compressor. Should I return the unit as defective, or can anyone out there advise??
    Re: R6903cfa oil free pneumatic hub-2 nailer combo
    I'm having the same problem - I don't want to return it though - I got too good a deal on it. The only outlet I have had luck with is the GFCI outlet outside (which does little good when I'm trying to do molding inside the house).
    I'm going to continue fishing for answers
    PK
