WD0635 Accessories
  • WD0635 Accessories
    I wish know if any way to use the RIDGID 14 In. Wet / Dry Vac Floor Brush with a Ridge WD0635 vacuum cleaner that have a hose of 1 7/8 ". Thanks you.
    Re: WD0635 Accessories
    What size is the floor brush, 2 1/2 inch? You might find an adapter from 1 7/8 - 2 1/2. Ridid sells 1 1/4 - 2 1/2. Might be easier to just buy a wet/dry floor brush to fit your machine though.
      Hi Killavolt. Do you have the part number of this adapter?
      Thanks a lot..
        Adapter kit does not work for 1-7/8" to 2-1/2", only 2-1/2" to 1-7/8". No floor brush seems to be available for the 1-7/8" hose. Bummer...
