Long term lith Battery Storage
  • Long term lith Battery Storage
    The instructions for the Ridgid R86006 18v compact cordless drill are a bit confusing as they incorporate Ni-cad batteries into there explanations.
    At some point the manual suggests that "batteries" should be stored for long periods at a 30-50% charge. I spoke with one of the Ridgid Tecs and he indicated that was only for Ni-cad batteries. Whats the real deaL? Does the amount a lith battery is charged prior to long term storage (4 to 6 months+) matter or not? The Tec seemed to indicate that a simple booster charge every 4 months or so would suffice? Any definitive answer?
    Thanks in advance..and there will most likly be some follow up questions, so check back in, if you will.
    Re: Long term lith Battery Storage
    How profound, he said definitive answer! That never seems to happen!
      Li-ion should be stored at 40% charge and 15-20 deg C. This is from manufacturer spec (Not Ridgid, from Moli Energy).
        Gentlemen thanks for the detailed responce, from my timed charging studies for these batteries, I guess with the 30-34 min. full charging time of the 130383001 18v Lith batteries that come with the R86006 or -7 Compact cordless 18v drill; a 12-13 min. charge time should approximate 40% of the normal full charge, if the chargers output is uniform throughout its charge time duration.
        I would have also indicated the 18v batteries "ah" (amp hours) for the 130383001, but I have heard conflicting ah's related to this particular Lith battery when doing my original research. Ridgid's website info on the R86006 battery specs were lacking and I see they are doing a better job on the new -7 specs.
        I noted some other MFGers indicated as little as 1.3 ah, and I thought Ridgids smaller 130383001 Lith batteries were 1.5 ah, which was what I found to be the largest ah indicated for any MFGers version of these smaller 18v Lith batteries. Once again talking with the Rigid Tec; he mentioned the 130383001 was a 1.4 ah, which was something different from what I had originally heard. He also recommended the 130383-028 Lith battery..I was wondering what the difference was between the -001 and the -028? and what the real "ah's" are?
        One more debunking Lith battery old wives-tale type of question mentioned by a tool dept. associate at Home Depot. He indicated that the full potential of a batteries "ah" would not be achieved until the battery was charged a number of times (5 was the number put forward) Was he confusing a Ni-cad trait with a Lith-ion battery? Now I have read about some cell phone battery potential, not being fully achieved until multipule charges have taken place. What do the experts say about this multipule recharge aspect and Lith-ion batteries.?
        I'll have to take a look at that Moli Energy Report.
