? on a troybuilt Honda 13HP with an AR pump
  • ? on a troybuilt Honda 13HP with an AR pump
    I just picked up the unit used,,This pump looks like a quality piece,,its the AR #RKV4G36,,,it resembles the general pump my buddys got and is also built in Italy,,does anyone know the track record on these?,,,thanks jim
    Re: ? on a troybuilt Honda 13HP with an AR pump
    That's the exact setup I have on my jetter. The Annovi RK pump still cranking the PSI pretty hard after nearly 8 years. Started right up this spring after sitting for 2 months.
      If you decode the model number it means the pump puts out 4 gpm and 3600 psi. I'd say a very good pump. Later!
