MS1250LZA and MS12502 conversion
  • MS1250LZA and MS12502 conversion
    I want to add the Laser to my regular (MS12502)saw. The Guard part numbers are different, but the clearance appears to be there. The arbors are the same size. I just can't see why this won't work. RIDGID says no, but it really looks like it will fit. The Laser replaces the outer washer and has a countersuck allen head bolt so the thickness is the same as the blade-washer-bolt. Any thoughts or input would be appreciated.
    I looked into the "universal" Lasers and they all only fit the small arbor saws.
    Re: MS1250LZA and MS12502 conversion
    My personal opinion is it just isn't worth it. For rough work they are okay but for cabinet work I use my tape measure. I have the 12" Hitachi and it has one but I don't use it.
      I appreciate your opinion, but I just needed to know if the RIGID laser would fit. I use the tape also, but the laser would be nice for production cuts (Laminate Floor)
