Honda GX carb flooding??
  • Honda GX carb flooding??
    I just picked up a 11hp honda gx,the problem is when i turn on the fuel it floods the motor,i pulled the carb and cleaned the whole thing including the needle and seat but its still flooding.thanks ahead for advice jim
    Re: Honda GX carb flooding??
    Does the float work? When you have the carb apart blow into the fuel inlet, can you stop the air flow by moving the float up?
      I pulled it apart again and it was leaking when I blew thru it with the needle pushed in the close position,it appeared to be leaking around the plastic needle seat so i pulled it out and cracked it while i was at it.dose anyone know were is the best place to pick up carb parts online? Thanks jim
        These guys are good
        They do have Honda parts but not sure what engine you have so can't tell if they have exactly what you want
          Hi W Brooks,,,I have a Honda 11hp 340GX max..Im not able to sort thru there webpage with much success,,what do you think about the generac carbs out there like this one on EBAY,this guy seems to sell lots of them and has a very good feed back?,,,thanks jim
          http://cgi.ebay.com/Carburetor-gaske...3%3A1|294%3A50
            If you remove the float, shake it. Sometimes floats develop tiny leaks and get partly full of gasoline and thus won't actually float. This results in serious flooding of the carb.
            As for brand X carb kits, please do yourself a big favor and stick to genuine Honda parts.
            You'll need the engine serial number besides the model number. Once you have them, try this link where you can download manuals. I hope this helps you.
            Manuals: http://www.honda-engines.com/Engines...uals/gx340.htm
            Engine specs: http://www.honda-engines.com/engines/gx340.htm#spe
              I tend to agree that in most cases OEM is better. M&D sells the OEM carb for $62.26 but you really should only need a rebuild kit. Take the carb into a small engine shop along with the motor Model and S/N, they should be able to get you the kit, or call M&D or others and tell them what you need.
