Air compressor
  • Air compressor
    I need a recommendation on an air compressor. I had a Porter Cable pancake type compressor, it lasted 4 yrs. I need a new one now. I want a light weight and kinda small one that will fit into a small job box. Any good buys on a website?
    Thanks, Tim
    Re: Air compressor
    all depends.... what is it exactly that you want to use it for?
      Re: Air compressor
      I have the 2-gal version of this Craftsman 1-hp, lube unit:
      http://www.sears.com/shc/s/p_10153_1...+%26+Inflators
      I believe the compressor and drive motors are the same, but mine is a bit smaller (2 gal tank with compressor/motor sitting just behind the tank, both surrounded by a roll bar like hand. Very small and relatively lightweight.) I can't find the image, because it's currently on close-out.
      It's great for running your nailer or inflating tires, but doesn't have the cfm for much more. Either unit is very quiet compared to the oil-less pancake types.
      I hope this helps,
        Re: Air compressor
        Main use if doing air test on plumbing and gas lines. Need to be able to pump 100psi.
          Re: Air compressor
          most will do 100psi its just how fast it gets you there thats the rub. if you have a whole building to test it may take an hour or more to pressurize all the lines with a small compressor. Also youll need it to maintain that pressure barring any leaks.
          so my advise would be to look for one with at least 1 1/2 HP and in a size you can live with.
            Re: Air compressor
            Hey... I want an wind powered air compressor . Can anyone provide me some information about it. Looking forward for your reply.
            Vacuum Systems | Industrial Pumps |Centrifugal Pumps
              Re: Air compressor
              I'm not aware of any "wind powered" compressor. "Wind Power" may help you generate electricity which in turn might well drive a compressor, if it the current and voltage is ample enough.
                Re: Air compressor
                Home
                I do not know how much psi they will pump, there more for pond aeration and air lift pumping systems,
                or a air driven pump for water, to my understanding.
                but for the original poster I do not think it will fit in a job box,
                There was once a system that worked off the stroke of a water pumping wind mill that moved a cylinder, (it was for pond aeration, it was sold by O’Brock Windmill's). Home
