adjusting the riving knife on r4511 table saw
  • adjusting the riving knife on r4511 table saw
    I'm having troubles getting the splitter (riving knife) adjusted correctly on my r4511 table saw. Do any of you have any helpful hints? The manual is no help at all.
    Re: adjusting the riving knife on r4511 table saw
    It's very easy. Take off the blade and you will see two set screws there. Slightly loosen them and move the riving knife in the direction it needs to go and tighten the screws. Put the blade back on and check. You may have to do this several times, but once it is done, that should be it. Good luck. And yes, the manual is only good as a fire starter.
    Red
    Red
      Thanks Cactus, I just bought one of these and the manual didn't make any sense on this. I will try your method tomorrow.
      Brian
      Brian
