Miter Box fine adjustment
  • Miter Box fine adjustment
    I have a model MS1250LZA miter box. It cuts 2-3 degrees off on the horizontal cut. I have adjusted the vertical but can not find the horizontal adjustment.
    Re: Miter Box fine adjustment
    I do not have the saw you mentioned, but on some, the horizontal adjustment is made by moving the fences. Loosen the hold down bolts, clamp a straight edge to them to keep them aligned, adjust to square with the blade and re-tighten.
    Go
