Lost (black) soap nozzle for ExCell VR2800
  • Lost (black) soap nozzle for ExCell VR2800
    I have a pressure washing job tomorrow and I lost the soap valve... I'm low on cash and nobody sells individual nozzles around here. Is there a possibility I can drill a larger hole in one of the other nozzles to resemble the soap nozzle? Looks like the the black nozzle has a larger hole which enables the chemical hose to suck the solution. Any thoughts of any kind. The chemical solution won't suck up the hose with a high pressure nozzle.
    Thanks,
    Chet
    Re: Lost (black) soap nozzle for ExCell VR2800
    you could try to make one with a 1/8" or 1/4" pipe cap, and drill a hole, (if you have some type of threaded fitting to attach it to, (the spray nozzles are more than likely hardened so one would have difficulty drilling it).
