TP1300 Upper Frame Adjustment
  • TP1300 Upper Frame Adjustment
    Hello,
    I have a TP1300 Surface Planer and the handwheel got stuck. The handwheel adjust the height of the upper frame and the cutter. When I tried to adjust the height it would only move up or down a quarter inch. I removed the covers on both ends of the transmission shaft to clean debris from the worm gears, the problem I am having is the upper frame will not go all the way down so, I think the worm gears and the elevating scews are out of time or sync if you will. If any one has a remedy for this adjustment.
    Please let me know.
    Thank you
    Dave
