14" bandsaw Ridgid
  • 14" bandsaw Ridgid
    I have put together my saw and went by the book. But every time i track it the lower tire comes off. i have tried more tenion and less but it still comes off. any had this happen to them?
    Re: 14" bandsaw Ridgid
    Have you checked to see if upper and lower wheels are coplaner? I had to put a long (4') level up to the saw and adjust the upper wheel to be in the same verticle plane as the lower. If the lower is too far "in" you may have to take it off and add some shims behind it.
    To adjust the upper wheel, use the knob on the back. There are two knobs on the back of the upper wheel. One adjust tension, and the other adjusts the upper wheel in and out.
      It could also be that the tires are just loose and stretched out. This happened to me after about a month with my bandsaw, but it was the upper tire. Just kept slipping off whenever I turned the bandsaw on. The stock tires are pretty crappy...
      Replaced 'em with urethane tires and problem solved.
