Help for a new member
  • Help for a new member
    I could use some help on my Lithium Ion Ni-Cad Rapid Max charger. I bought my 18v Ridgid cordless screw gun with 2 batteries, charger and a bag. I charged both batteries when I got it and used one of them. When the first battery was discharged I tried to charge the battery the charger and the battery will not charge at all. The charger light will not come on. Can anyone help me with this problem? Yes it was pugged in and the battery was on the charger correctly.
    Re: Help for a new member
    If you have tried cycling both batteries several times without any response from the charger something is probably defective with the charger. You don't tell us how you purchased this kit and when. If you purchased it from Home Depot within the last 90 days simply return the entire set for exchange. If you purchased it elsewhere you will have to follow their procedure.
    Good luck.....Ray
      If you insert the other battery in your charger what happens?
      We need more info and need to know if the issue is just with one battery or both of them?
