R842301 impact driver vs. R86230 impact driver
  • R842301 impact driver vs. R86230 impact driver
    What is the difference other than the fact that they are part of different kits? Thank you!
    Update: Called RIDGID, one has light and the other doesn't. The changes are cosmetic.
    Re: R842301 impact driver vs. R86230 impact driver
    r842301 is the original 18v [only] impact driver 1450inlbs 0-2400rpm blows per minute 0-3100 no led
    r8823 max select 18/24v 1490 inlbs has led
    18v=0-1700rpm blows per minute 0-2900
    24v= 0-2100rpm blows per minute0-3300
    r86230 18v [new one in kit] 1450inlbs 0-2400rpm blows per minute 0-3100 has led
    The specs for the r86230 came from a second source and I can't verify the information but
    I believe it's likely to be accurate
    Cactus Man
