All 3 batteries dead & unchargeble at the same time?
  • All 3 batteries dead & unchargeble at the same time?
    I went to use my Ridgid drill with my Ridgid 18v Max HC battery and it was dead. I tried my other 2 and they were dead as well. I tried to charge them but the carged would not start the charging process, it would stay blinking red. I have gotten plenty years out of this set, but for all of them to go out at the same time seems odd. Thoughts?
    Re: All 3 batteries dead & unchargeble at the same time?
    You don't say how long its been since you successfully used the batteries.
    I would be very suspicious of the charger since you get the same response for each battery and none takes a charge. You also could have a drill that is shorting the batts and killing them.
    Whatever, the good news is, since you registered your tools for the SLA when you purchased them, simply take the entire set of batts, drill and charger to a Ridgid service center near you for analysis and replacement of the defective item.
    You did register the tools didn't you!!!!!
    Ray
