Question on 80701 3K pressure washer
  • Question on 80701 3K pressure washer
    Stupid question #1: Why are there there two oil fill/dipsticks on the motor?
    Stupid question #2: What is the correct level on the oil for the pump on the window site? How often should I change it? I'm asking because I did'nt see it in the manual.
    By the way, the detergent fill tubes are not so good. Had to tweak them to make them work.
    The machine works awesome overall. Starts up quickly and has tons of power.
    Re: Question on 80701 3K pressure washer
    Answer to question 1...... the engine can be used in many different applications and they usually put one on each side to allow access for these different engine configurations.
    Have no idea on the second question. I'd contact the pump manufacturer and go from there. No info in the manual? Later!
      Fill to red dot on site glass on front of pump. Initial change is at 50 hours, 500 hours thereafter. I had same prob with detergent tubes
        Can you elaborate on the tweaks please
          Just remove kinks and straighten. Also had to cut about an inch off the end of one that was badly kinked.
