Pressure Washer
  • Pressure Washer
    I purchased a Gasoline Pressure Washer model # RD80746. Starts and runs ok. I do not know how to increase the amount of pressure from the unit.
    I could not find this in the manual and those at home depot were no help at all.
    Help is appreciated.
    Thanks
    Steve
    sportswave@dccnet.com
    Re: Pressure Washer
    Usually most PWs come out of the box with the pressure maximized. There may be an adjustment on the unloader to decrease the pressure for more pressure sensitive items you might be cleaning. BUT you should never try to increase the pressure more than what it is out of the box.
    If you're not satisfied with the pressure like it is you can decrease your nozzle size (smaller orifice in tip), but you have to be careful not to overpressurize the system by doing so. Later!
