Another TS2424 1 question
  • Another TS2424 1 question
    I just noticed that my recently purchased TS2424 1 has a 12 inch blade installed. I thought that this was a 10 inch saw??? I downloaded the available manual, but it is sl;ightly different than the saw I have.
    Can the TS 2424 1 use a 12 inch blade?? Jim
    Re: Another TS2424 1 question
    2424 is meant to be a 10" saw. The arbour should be 5/8" the hole in the 12" blade should be 1", how is the 12" blade centered on the arbour?
      Some 12" blades have 5/8" bore, some also come with a 5/8" bushing. If it's truly a 12" blade, you'll have to be very careful not to raise it up too high or the sparks (and shards) will fly!
        Opps shame on me . I looked at the spare blades I recieved with saw, they are 12 inch the blade on saw is 10"
        JIm
