2600 ros
  • 2600 ros
    I have a 5" ROS and the sanding pad spins out of control when no pressure is applied. What I'm not sure of is whether I need to replace the brake skirt, the sanding disk, or both?
    Re: 2600 ros
    You may need a new break skirt 590936001 or you may just need to disassemble and clean out the saw dust
    Here is the exploded diagram, break skirt is part 39.
    Are you sure this is not covered under the LSA or warranty?
