15 Ga Angle nailer
  • 15 Ga Angle nailer
    Just purchased display model 15 Ga Angle nailer.no case or manual. I noticed there is a white plastic plug just inside the handle where the air hose connector is. Should this be removed or is the in handle air filter mentioned in the online manual. There is no npt connector on the unit now. If this thing stays how does the oil get to the inner mechanism of the nailer?...........Devon
    Re: 15 Ga Angle nailer
    I believe you are looking at a plug to keep contaminates out of the gun until the proper connector has been installed and it is ready to use.
    A picture would be helpful. Is it preventing you from adding the connector?
      Thats what I thought at first until I read the manual online . Will remove the base of the handle and remove plug and see if there is anything else in there that looks like a fliter. The plug looks and feels pretty solid just from sticking my finger in there.....Thanks ....Devon
