tp1300 issue
  • tp1300 issue
    I have a TP1300 adn when I run wood through and take more than 1/32 off the motor bogs down and stops completely... anyone else ever had this issue? I checked the brushes and they are fine any ideas???
    Re: tp1300 issue
    Dull knives, dirty rollers or both would be my guess. Also, rewaxing the table every so often is a good idea.
    Diapers and Politicians need to be changed often... Usually for the same reason.
      Re: tp1300 issue
      I would say your motor is shot. Even with really dull knives you should not be able to stall the motor unless you are plaining 1/8" off 13" wide Lignum vitae. Stalling the movement of wood through the planer is another story
