R4511 Blade problem
  • R4511 Blade problem
    Just bought this from Home Depot (was a return). When I begin cutting a pc of wood, about 3" into it, the blade will stop spinning. The shaft spins, but not the blade.
    Nut is tight, it has the washer on eaach side of blade + nut.
    I don't have an owners manual, or parts list/repair list. can't find in on ridgid.com.
    Any suggestions other than return it to Home Depot?
    Thanks
    Re: R4511 Blade problem
    There's actually a recall on these saws. You might want to check it out, to see if that's the issue you're having:
    http://www.ridgid.com/Download/R4511_PR.pdf
