6.5 amps
  • 6.5 amps
    is 6.5 amps alot of power?
    Re: 6.5 amps
    What do you mean by a lot? Power is measured in Watts, not amps. So You could have 6.5 watts at 12V and you would get 78W. If you have it at 240V, you get 1560W.
    A standard household circuit is 15A, and new kitchen receptacles should be on a 20A circuit.
    A table saw or router is probably about 12-15A.
    I noticed this was in the power tool section. What tool are you thinking of?
      Re: 6.5 amps
      a 6.5 amp corded drill
        Re: 6.5 amps
        In most cases that will be plenty until you get into the SDS applications
          Re: 6.5 amps
          ok thank you
