3650 ticking
  • 3650 ticking
    Hi guys, I'm hoping you can help me solve a prolem I have with my 3650 table saw. I adjusted the 90 degree blade stop just a little fat so when I get a little saw dust build up in the adjustment slot I can still get 90 degree cut, I always use a square to check bade angle. And I changed the blade and put in zero clearance throat plate and my blade starts ticking sound when the motor is running but as soon as I turn saw off ticking stops even though blade is still spinning. I took zero clearance plate out and put old blade back in but it still does exactly the same thing. I also checked belt & don't see anything there and I dont feel any side to side movement in blade. Everything was ok until I adjusted 90 degree stop & changed blade & clearance plate. Can anyone help me with this delima?
