RD6800 Alternator
  • RD6800 Alternator
    Does anyone have the specs on the RD6800 or do you know anything about this alternator? I'm particularly interested to know if it is brushless and does it contain copper windings.
    Re: RD6800 Alternator
    6800 Watt Generator
    RD6800
    Features
    GenSmart Monitoring System - tracks usage, load, and indicates periodic engine maintenance
    8 Gallon Steel Fuel Tank with Fuel Gauge - extra long run time for up to 12 hours at 50% load
    Removable Control Panel with Engine Start/Stop Switch - brings the essential controls directly to your work area
    Roll-Cage with Fold-Down Handle and Skid Rails - excellent jobsite maneuverability and protection
    Armourâ„¢ Heavy-Duty Alternator with Auto Voltage Regulation - reliable and clean power for your tools & equipment
    25 ft. - 20 A Removable Control Panel Cord Included
    Specifications
    Running Watts/ Starting Watts: 6,800 W / 8,500 W
    AC Voltage / AC Frequency: 120 V / 240 V, 60 Hz
    Rated Amperage: 56.7 A / 28.3 A
    Engine: Yamaha MZ 360 OHV
    Displacement: 357 cc
    Fuel Tank / Run Time (@ 50% Load): 8 Gal / 12 Hours
    Unit Weight: 228 lbs.
    Height: 27 in.
    Width: Width: 30 in.
    Length: Width: 30 in.
    Includes
    6,800W Portable Generator, Removable Front Feet (2), Removable 12" x 4" Never Flat Foam Filled Wheels (2), 25'-20 A Removable Control Panel Cord, Cord Holder Strap, 2 Fl. Oz. Engine Lubricant, Assembly Hardware, Operator’s Manual
    rockwell sonicraft |rockwell sonicrafter|fein fmm blade |power tool|Fein top|tools
      It does have brushes. And it does have copper windings in the rotor and stator.
        does anyone know if this RD6800 generator provides what they consider "clean power", less than 5% THD? It mentions voltage regulator, but no specifics. Has anyone been using one to run some home appliances, etc. with any power fluctuation problems?
        Also, are brushes prefered over brushless for the alternator?
        thanks.
