Ridgid Compressor runs continously
  • Ridgid Compressor runs continously
    I have a Ridgid twin stack air compressor (OL50135AL) that is running almost constantly to build up air pressure to 125psi. It isn't leaking air from anywhere, it just appears not to be building up pressure in the tanks like it used to. Any thoughts on how to diagnosis this or where to start? Thanks.
    Re: Ridgid Compressor runs continously
    You may have either bad rings or piston on the compressor. I have a shop oil less compressor and I have had to replace one piston and the rings in the past. The compressor is now getting to the point that I need to replace the rings again (takes a long time to build up pressure).
    Bilcor
