R8660 No Bits Available
  • R8660 No Bits Available
    Hello, I am new to this forum so please keep that in mind. We are currently drywalling our Church, which is a huge task. I went to Home Depot and bought the r8660 cordless drywall screw gun. It is amazing. However, After wearing out one bit I have found there are no replacements available. Rigid customer service told me to return it for a new one. However, they do not have any in stock. I have called numerous Home Depots with no luck. Please help me find a source for the bits. Thanks in advance for your help. Blessings, Matt
    Re: R8660 No Bits Available
    here is another thread on the subject,
    http://www.ridgidforum.com/forum/sho...d.php?p=194930
    post number #15
    it appears to be a problem on getting bits, maybe some one else can guide you better, hope so.
      check with your local service center # 2 phillips part number 670800093
      around $3.50 each
        Use the senco bits. Lowe's has them too.
          if they are 1/4 hex, get longer ones and just cut them off with a grinder with 1 mm disc.
