Ridgid collated screwgun
  • Ridgid collated screwgun
    Recently bought the Ridgid collated screwgun (corded) and am trying to find some decking screws. All I have been able to find were Senco exterior.... It lists that they are compatible with Makita, Milwaukee, Pam, and Hilti guns. Does anyone know if they will work with the Ridgid? If not any suggestions on where I can find compatible exterior screws? Thank you
    Re: Ridgid collated screwgun
    They will. If you compare the Senco gun to the Ridgid gun you will see that they are the same.
      Basically 2 styles, Senco, Milwaukee, Makita, Hitachi, Ridgid all use the same collation,flexible strip, the other is Quick drive, a stiff short strip uses a totally different system. I use the senco screws and the exterior are very sharp special tip, no predrilling needed, Home Depo used to have a good selection, now few are there , no 3" at all. Typical, HD is just awful with support for products they sell.
